If I want to make a VPN Tunnel with Fortigate 100 & MAX-BR1. Is it require to buy the advanced feature pack ?
Aside from our proprietary Speedfusion protocol, our router also support IPSEC. You can try establishing an IPSEC tunnel between the 2. For BR1, it’s under “Advanced, IPSEC VPN”.
Kevin
