I would really appreciate to have to possibility to add speedfusion-tunnel to devices, which have tunnels, that are controlled by Speedfusion.
My “Hub-devices” are configured through InControl to build a star-topology.
Currently, I am not able to connect to devices which are not controlled by my InControl appliance (devices of business-partners).
I’m not sure exactly what your use case is, but for several versions now, you’ve been able to connect your star-topology hub to devices not managed by IC2. This allows for you to set up connections between devices in other orgs, devices controlled via private ICVA instances, and locally administered devices. When administering your star topology, click the “Advanced” checkbox, and “Add Device” to add an externally managed device.
Thank you! I have not been aware of that feature. I thought about the possibility to configure additional devices on the device itself, but in this case, using IC2 is great, too.
