I have a modest home setup: a Peplink Balance router, a couple of access points, and a few wired devices, and I want to watch traffic without breaking the link between them. A passive TAP seems cleaner than mirroring a port, since my switch only has one spare port and I’d rather not lose the ability to use it for something else. I came across Dualcomm ETAP-2003 Gigabit Ethernet Network TAP Review while comparing options and I’m trying to work out whether an inline TAP like this makes sense for a small home network or if it’s overkill. My worry is that inserting a TAP in front of the router could introduce a failure point if it loses power, and I’m not sure whether the monitoring ports need a dedicated capture device or can feed a plain laptop. For those running a TAP at home, how do you keep the link reliable when the TAP itself loses power?
