I am having trouble configuring the Pepwave One AP.
It is connected to a LAN port on the Peplink Two but does not show up on the AP management features tabs.
The firmware is the latest.
No clue with just this info, but there’s always the old, “are you absolutely certain the ethernet cable is OK?” If you have a tester, that might be a good first step.
- Make sure you’ve enabled the controller …
- Can you see the AP in your list of connected devices LAN-side? [essentially what @Madcodger is suggesting.]
- Do a factory reset on the AP.
Factory reset was the fix. Thank you.
You are most welcome. :<)
