Please add support for DDNS provider Dynu.com, including the option for SSL security when phoning home. They claim to support the DYN API. Thank you.
I am using Dynu and was able to use the Other option with the following parameters:
Url: api.dynu.com/nic/update
Username and password: as in your dynu account
Hostname: as in your dynu account. E.g. test.kozow.com
I did the same, works like a charm
Does this still work? I tried:
No success. The 2018 fix above was for v1 API. Any ideas what works for v2 API?
Dynu v2 is using HTTPS, this is not supported yet
Detail info :
