Add SFC interfaces to Active Session Interface selection
Currently, SFC shows in the interface column, but I cannot “search” by SFC interface, only via one of the “Physical” interfaces.
but if SFC is shown in the interface column (as it should), I should be able to search/filter for these sessions.
@avic That’s right. I see what you mean and that is an enhancement missing from the Active Session search function. Will follow up on this. :wink:
@Eddy_Yeung can you please also ask them to add “exclude” to the search filters?
for example, I am using PingPlotter that issues a ping every 0.5 seconds and plots the latency times and sends notifications,
I’d love to be able to exclude ICMP from active sessions.
@Eddy_Yeung also the overview table does not show SCF interfaces
I too wish “Active Sessions” showed virtual interfaces, not just physical. Right now I have click through and search for sessions using “VPN” but that’s not as fast or as precise.
