Add option to advertise local AP network as metered
Hello, it’s possible to advertise a WiFi network as metered so that clients do not try to download large optional data blocks like system updates in the background. Can Peplink advertise its AP as metered, in the case the sim card has limited “high speed” data or incurs charges for incremental data usage? I could not find such configuration in the current UI.
See also Configuration to tell dhcp clients they're on a metered connection? - #9 by soylentgreen
Soylentgreen,
Is there a solution ?
