I have a wireless network with old AP One’s that I created 6 or 7 years ago. I am about to embark on upgrading the Access Points. Can someone point me to the proper method for configuring the new APs? I am managing them through the InControl Cloud Administrator. Since it’s been awhile, I wasn’t sure if everything was the same or not. I believe I just put the static IP on them then InControl downloaded teh configuration automatically? Is that still the way it goes? One caveat is that this new unit will be added as a second unit in this regional office. What do I have to do special to allow two AP’s to exist in proximity to each other?
Thanks!
I would suggest you to contact Peplink local partner for assistance. Further study require by the local partner in-order to advice the necessary upgrade & migration plan.
You can find the contact list as below:
https://www.peplink.com/peplink-certified-partners/
