How i can add another user like admin in peplink.I just see the line user but it just can read only.
It’s not possible to create another admin account on device level.
I would suggest using InControl 2, which makes it possible to give certain rights to accounts.
You can use the following roles in InControl 2:
Another option: do consider enable radius authentication for the Webadmin access then you can define multiple admin user account base on the radius users.
