please consider adding an “ACL” button to IC2 & RWA Client List.
IC2
A button with a dropdown list allowing to add a Client to an existing or new ACL could be very useful. It would make whitelisting and blacklisting much easier. An “Action” column could be a good place for such a button.
sorry, I didn’t notice that.
It still does not allow me to fully manage my network. In my case, I use MAX router with several AP One, all managed via IC2. Most Wi-Fi Clients are connected to AP’s hence are seen by the router as “wired” and I can’t easily block them.
Also, this feature only allows blocking specific Client. What I am asking for is an option to add the chosen Client to an ACL which could be assigned to any network: Captive Portal, SSID or Firewall rule.
This is supported if the AP is running above 3.7.3 or 3.8.1.
So, you are looking for a simple way to add the WIFI client into ACL, firewall from Status > Client List to block them instead of going to the firewall setting page, am I right?
thanks for the feedback, I’ll upgrade the fw and check this feature on our APs
Exactly! It would be much easier to spot an unwanted client and block it directly from the Client List. I would also appreciate adding ACLs to the Web Admin Interface.
