Add ability to do filtered packet capture on support.cgi
I am having an issue requiring packet captures to solve. I can do one on the remote peer with no issue, but a raw packet capture on the central balance 710 with 120 active peers is very difficult to use.
It would be very good if we could do one or more of:
Apply a packet capture to a speedfusion peer
Apply a packet capture to a specific remot subnet.
I know this may not be possible, but it would help.
Easiest way to do this would be to filter your capture in Wireshark, its pretty simply to use the ip.addr==x.x.x.x command to look for specific hosts or networks in a large capture.
The issue is that since out B710 is connected to almost 200 peers a packet capture there overruns the buffer in seconds.
Do you try before using remote capture ?
I had not seen that ability. I will try that
