a customer want an ACW-622 power supply to enable POE.
When you connect the ACW-622 the LAN port will automatically be POE? Or is there a procedure to apply?
What other peplink device are you using this on?
The ACW-622 is just a POE injector it should take Data in on one port and data/power out on another port?
I think to further answer your question their isn’t an activation sequence required.
