how to access the internet using combined bandwidth of all my wan
- Buy a router that all your WANs can plug into that supports their combined bandwidth.
- Use that router as load balancer and multiple sessions (from different applications or different users) can be load balanced across all available WANs using all available bandwidth.
- If you want a single session (like a file upload or a video stream) to be able to use all the available bandwidth (less than with load balancing) use SpeedFusion Bonding to the cloud. Just make sure the router you buy supports enough SpeedFusion bonded throughput for your needs.
