I have a Peplink Balance 30 in a remote location whose internet is provided by DSL and Starlink satellite service. DSL has a fixed IP, Starlink has carrier grade NAT. My lan at that location is a typical 192.168.xxx.xxx network.
I have FusionHub working on AWS and the bonded connection is working remarkably well considering the connections (the DSL line is about 18,000 feet from the Telco equipment and the Starlink dish is pointing up through a pretty constrained hole in some tall trees).
I want to be able to access the network from the WAN via a VPN client (from a Mac) so I can access any of the devices in the 192.168 LAN, as well as port forward to some of the machines. But I want to do it through the AWS fusion hub so I get the benefit of the bonded connection (and a fixed IP address).
I’ve been unable to figure out how to do this. I can setup remote access on the actual Peplink hardware, but can only apply it to the individual WAN connections. I have setup a VPN remote access account on FusionHub, but can’t get it to work (and then have no idea how to channel that traffic back into the 192.168 network). I setup the port forwarding on both devices, but can’t get that to work either.
One of the issues is that I’m not even sure what IP address I should be using. AWS gave me a 52.70.118.xx address, but the interface to the FusionHub on AWS says the WAN IP is 172.31.95.xxx.
I have a case going with support - originally the FusionHub wasn’t working with Starlink; they got that to work but I haven’t gotten specific help on getting the remote access VPN client to work nor the port forwarding.
Any and all suggestions are appreciated.
