Access to Max BR1 5G without IC2
Hi
My warranty is expiring and I don’t wish to pay 150$ a year just to access my router through IC2
Is there a way to access the router directly please. This is a personal device, not for company usage.
Thank you!
From inside the LAN, you can access the routers admin page on its internal IP address.
You can also use a DynDNS thing and open up the admin page on the WAN, but be aware for security risks in that case.
also ic2 should not be $150… its 1/3 of that or something.
@mystery
Hello…
Yes… but will need to buy OpenVPN WAN License (LIC-OPN-WAN) for your BR1 Pro.
Connect your device to openvpn, configure and connect it to openvpn cloud service.
Download the APP for your iOS/Android. Configure it… Use the openvpn service to start your access to cloud… Then use the Peplink app or your browser to access your BR1 pro.
thats primecare, if you dont want the warranty/primecare features, you can pay just for IC2 i believe.
hi.
LIC-OPN-WAN it is a license… will keep it at your device forever. Don’t neet to have primecare to keep this license work. Also… Maybe I am wrong… but… you can sign open vpn service at openpvn url, for free. up to three devices
