I am trying to make use of the GPS receiver in the MAX BR1 without having the cellular radio connected to the provider.
I do not have WWAN, and do not see a way to disable the radio.
How do I do this, if I can?
Thanks.
Thanks.
Nevermind. I figured out that I can drag and drop to the disabled section. So different than the Cradlepoint I’m used to, I did see how user friendly that is! ![]()
