I have an couple of Ubiquiti edgerouters behind a balance 710. They are getting internet via DHCP.
What is the most simple configuration to access the edgerouters from a remote location?
By access, do you mean to manage them? If so you could use InTouch which will be safer than a port forward
Or a VPN to the B710 and then you can access the edgerouters through that.
I already have a VPN working between the balance710 and a balance two. They are in separate locations.
Remote location 1: Balance two - LAN 192.168.100.1
Remote location 2: Balance 710 - LAN 192.168.101.1
Edgerouter 1 IP - 192.168.101.2
-LAN 192.168.200.1
Edgerouter 2 IP - 192.168.101.3
-LAN 192.168.300.1
Each Edgerouter has it’s own LAN. All the devices that I need to manage are in the Edgerouter’s LAN.
I need to manage the devices under the LAN 200 & 300 from remote location 1.
Ah I see.
The easiest way to do this is to disable NAT on the edgerouters and add static routes to the Balance routers for those 200 & 300 networks with the WAN IPs of the edgerouters as the next hop gateways.
Alternatively, you could do port forwarding on the WAN of the edgerouters to the devices you want to manage, then use Intouch to the edgerouter WAN IPs and respective ports.
