Ac mini - local login, no longer using incontrol 2
Hi All
I have not been using incontrol2 for a couple of years now. I wanted to locally login to upgrade the firmware however the admin public does not work.
What state has incontrol2 left the mgmt password in?
If you had web admin overridden with randomized password in inControl2:
If you can still login to InControl the AC MINI should still be listed and password accessible.
If not, I think the only thing you can do is factory reset.
Gosh,
I can still access incontrol2 and I can see the 3 unmanaged offline (but they are online) APs.
What do I need to try from here?
THX!
Go into your group where minis are then check under settings and “device system management” and see whether you can “show password” or download admin passwords as CSV?
I can download csv, and it has all my wifi credentials. But no mgmt details.
