About the PepVPN/ SpeedFusion Peers License Key
Could anyone provide me with some feedback on my below questions about the PepVPN/ SpeedFusion Peers License Key?
Is the PepVPN connections add-on license (Product Code: PVN-LC-05; Product Name: Up to 5 PepVPN/ SpeedFusion Peers License Key for Selected Models) a perpetual license?
Can I purchase the PepVPN connections add-on license (Product Code: PVN-LC-05; Product Name: Up to 5 PepVPN/ SpeedFusion Peers License Key for Selected Models) over a Peplink device with expired warranty? In the event that the answer is no, can I date-back the warranty plan for my device?
Any advice would be appreciated. Thanks.
Yes it is.
Yes you can.
I have B One and i am using it as Hub and need to connect the 6 Sites trough speedfusion VPN but in B one showing max 5 peers please guide me how i can buy the license to increase the Number Of peer in B one router ?
You can buy a license to increase the limit to up to 10 PepVPN/ SpeedFusion Peers License Key for Selected Models (PVN-LC-10) for the b one 5G.
5G store sell it online, or you can buy from your existing reseller.
Is that valid for the B one or only the Balance one?
It’s listed as an option on the Peplink store for the B One 5G.
Thanks @MartinLangmaid can you please let me know if i can upgrade the speedFusion Peer to 20 VPN in B one router ?
Hi all,
We understand that the Balance 310 provides 2 base SpeedFusion VPN peers, which increases to 10 when the device is under PrimeCare. If we need to expand this to 20 peers, we would purchase a PVN-LC-20 license.
Suppose a customer finds 20 peers insufficient and upgrades to 50 peers by purchasing and registering an SFN-LC-50 license. In this case, can the previously purchased PVN-LC-20 license be transferred to another device? Or is the license permanently tied to the original serial number once it has been activated?
Best Regards,
Kevin
do you get the answer ? i am facing same problem now. is pvn-lc10 stackable ? i mean 2 pvn-lc-10 is same with pvn-lc-20 because currently i only have 1 pvn-lc10 and need extend to 20 vpn
