I would like to be able to add starlink, cell, and bridged WIFI as priority 2 and then rank which is used first second and third. If this can be done without a feature add; I would love to know how.
I would like to use the campground unless it drops to a certain level then move to starlink, and finally cell.
Swap index.cgi at the end of your url with support.cgi, then click the link for “SpeedFusion VPN Traffic Distribution Mode [open settings page]” … That will take you back to your speedfusion config page, but now the advanced options will be enabled to choose that traffic mode.
Im not using speed fusion. I want to be able to rank the 3 connections in priority 2 based on cost. So starlink first, then campground wifi, then cellular. As it is they are all three equal and I dont want to burn through cell data while starlink is up and online.
Well generally you would use the “overflow” option under outbound policy, but you will notice that WiFi WAN and Cellular are not options for overflow, so it won’t do what you want it to. It has to do with needing a well defined bandwidth metric and they don’t treat WiFi WAN or Cellular as well defined bandwidths. There isn’t a good way to do what you want…
You could define a priority in the outbound policy of 1. Wifi WAN, 2. Starlink, 3. Cell and then put really strict healthchecks on the connections so they fail quickly to the next service. However with that approach you are only ever using 1 connection at a time.
