It would be useful to be able to change the WAN priority level from the IC2 device dashboard, without having to go to remote web admin interface. Often it takes longer to load the whole page, especially with slower connections.
On top of that, it would be useful to have IC2 perform the configuration rollback if when you change the priority it takes the device offline, similar to how other IC2 changes work.
Thanks!
For me, being new here, its incredible that something can only be done on in control, others locally, other via peplink app… This needs to be unified!
Alnavasa - Welcome
There’s some features that are as you say only available on certain platforms for control - some for good reasons.
It would however be very useful, as a new person to Peplink, to give some feedback on this and we can improve the product to accommodate things we may be too biased to notice.
Thank you, and appreciate the input.
+1
I agree this would be useful - especially if a device has a slow performing line that makes loading the UI slow or difficult.
The rollback feature also sound like a valid thing to have if this is causing an offline device - but would mean to include in the device FW also. Perhaps a bigger job than just IC2 changes.
Worth checking with the Peplink team for sure!
+1 For sure!
Also the rollback feature works when the device loses connection with IC2 after config changes. I’d be suprised if that doesn’t work with changing WAN priority
Hi nik, I’ve being out recently, I’ll sum up what my needs/opinions are related to this, but don’t know if they might or might not help others
Definitely +1 regarding WAN priority changes from IC2
Currenlty I can only change wan priority via peplink app on the phone, not locally (it reverts back to mobile phone) On the phone I only see drag and drop options, to priority one two an disabled,
I want to set starlimnk as one, cellular as two, and local wifi wan as three. But I can’t.
