I have a question about the Balance 20X router (that I am considering buying to replace my Surf SOHO. Short summary, if I replace my Surf SOHO with the Balance 20X, will its internal Cat 4 LTE modem accept my existing Verizon Jetpack AC791L sim card, and just continue to work using my Verizon 4G service directly (instead of the usb tethered via Verizon Jetpack)? If needed or of interest, background details on what I have and why I want to upgrade to the 20x are listed below. -thanks!
Today, I use the Surf SOHO with a Verizon Jetpack 4G LTE Mobile Hotspot - AC791L that plugs into the SOHO’s USB port. The Jetpack plugs into an Panoram Antenna DMM-7-27-2SP 2X2 MIMO external antenna. I use the Jetpack in tether mode, that I set on the Jetpack directly. I have used this for years at my home and it works great.
I am looking to upgrade the router to support the higher bandwidth of 5G cellular. I may well keep Verizon 4G, and add T-mobile 5G (T-mobile has better coverage at my house and Verizon does not offer 5G at my location). I have a test setup in place using a friends T-Mobile Gateway attached to my SOHO’s WAN port and the Verizon 4G modem attached to the SOHO’s USB port … so I have automated backup for Internet access right now in test mode (capped at around 110mbps due to SOHO throughput. If I connect my laptop ethernet directly to the 5G Gateway I get 400-450 mbsec to the Internet.
If upgraded to the Balance 20x, would its integrated cat 4 LTE modem accept the sim card from my Verizon Jetpack, allow me to connect my external antenna, and just work (effectively replacing the jetpack hardware with something more reliable … e.g. no battery to attend to)? I am unsure if my 4G service will work if I cannot use the Jetpack to set the mode to tethering.
