I have a MAX BR1 Mini that I am attempting to setup Default / Stationary GPS forwarding. The current firmware is 8.3.
Default w/o Stationary works as expected. When setting Stationary (100m / 300s) reporting every 60 seconds and Default at every 5 seconds, I only receive a message every 60 seconds no matter how far I drive.
I have also noticed that after applying changes to the GPS forwarding, the CPU load goes to 100% and stays there until I reboot the device.
Any ideas?
Have exactly the same issues.
Pepwave MAX BR1 MK2 (8.3.0s082 build 5131).
Have you found any solution?
I’m also having a related issue with stationary GPS when forwarded. I use it with Traccar for external fleet tracking. When a vehicle is stationary, it sets its position to the middle of the atlantic ocean, or sometimes some other random and incorrect location. Once moving, the position becomes correct again.
Both issues fixed for MAX BR1 MK2 in fw-max_br1mk2_hotspot_sohomk3-8.3.0s263-build5134.bin.
