Hi!
Can some body help with next problem
After Pepwave MAX HD4 was upgraded to 8.0.0 from 7.1.0 I can’t recieve access to managemet interface.
When I try to connect https://<ip_or_dnsname>/ device redirect me to https://<ip_or_dnsname>/cgi-bin/MANGA/index.cgi but I don’t recieve login form
I recieve ‘404 Not Found’ error page from nginx…
@wavemag
Please open a support ticket for support team to check.
Thank You
Regards,
Sit Loong
FYI I just reproduced this (by acciden!t) by attempting to go to httpS:// when I had not enabled SSL/HTTPS. I was able to log in by manually deleting the S and putting in just http://.
Hope this helps someone in the future.
