Renamed a WAN. Saved. Applied Change. Multiple Times.
Everything in web access shows the Correct New WAN Name.
However, in the event log, it still shows the Old Name for the WAN.
Need to reboot to change the name in the Event Log
Have you try to make some changes that related to the WAN after you renamed it? I tested it was working fine (renamed WAN name showed immediately). Fyi, I tested on v6.3.0.
Changed name 2 weeks ago…
Mar 07 00:52:43 System: Time synchronization successful
Mar 07 00:51:44 DDNS: Domain xxxx.dns2.us updated successfully for RoadRunner 100 Mbps
Mar 07 00:51:43 DDNS: Domain xxxx.dns1.us updated successfully for FiOS 75 Mbps
Mar 07 00:51:43 DDNS: Domain xxxx.dns2.us updated successfully for RoadRunner 100 Mbps
Mar 07 00:51:42 WAN: RoadRunner 100 Mbps connected (173.169.xxx.xxx)
Mar 07 00:51:42 WAN: FiOS 75 Mbps connected (71.251.xxx.xxx)
Mar 07 00:51:34 System: Started up (6.3.0 build 2189)
Mar 07 00:50:28 System: Reboot from Web
Mar 06 17:27:16 System: Changes applied
Mar 04 07:39:28 DDNS: Domain xxxxx.dns2.us updated successfully for RoadRunner 15Mbps
Mar 04 07:39:28 DDNS: Domain xxxxx.dns1.us updated successfully for FiOS 75 Mbps
Mar 04 07:39:24 System: Changes applied
Mar 01 04:46:55 WAN: RoadRunner 15Mbps connected (173.169.xxx.xxx)
Mar 01 04:46:50 WAN: RoadRunner 15Mbps disconnected (No cable detected)
Feb 28 14:51:22 System: Time synchronization successful
Feb 28 14:50:41 WAN: Priority changed (Priority 1 - FiOS 75 Mbps, RoadRunner 15Mbps / Priority 2 - Verizon Wireless Mobile Internet)
Interesting. May I know which model you are using?
Anyway, below is my testing result on Balance 580.
Peplink Balance One
I tested on Balance One but can’t replicate your problem. Please find the screenshot below. I suggest opening a ticket for us to take a closer look.
