Hi, do any Peplink devices support 5G in SA mode? I notice all the datasheets for 5G compatible devices list NSA bands, but I’ve also seen some forum posts with screenshots showing SA bands…so curious if there’s official support for it.
I own a HD1 Dome 5G running 8.3.0 RC3 and i don’t see any SA bands available under the Band Selection dropdown menu.
Some do, you may need to open a support ticket to request a special firmware build but that is also dependent on specific models from memory.
We have been testing 5G-SA on a private 5G network using the Balance 310-5G and BR1 Pro 5G with firmware obtained from support.
the sierra models do, thales doesn’t as of yet, i ripped mine out and replaced:) if you have static ip on t-mobile, SA does not work, only NSA.
