Thanks … that bug was relating to the password field being truncated in the AP controller to 32 chars without warning.
This screen on the AP mini however, no matter what I do, I can’t disable the WAN connection. It doesn’t save. Is that because it is controlled by the AP controller in the B20x?
If these settings are ignored due to AP controller control then its fine, but I don’t believe the AP controller profile settings in the B20x has an option for WAN connection admin, only LAN admin.
May i know the WAN health check settings for the AP ? Using DNS ? Possible to change that and check again ?
WAN Health check was enabled on the AP Mini and set to default DNS check. I disabled it for now.
But for some unexplained reason, the blocked DNS rebind requests flatlined at 2:40am this morning.
I am now seeing the following unblocked requests
My B20x event log reported a System startup event at exactly 2:41am and WAN connected at 2:42am…
Not sure what to make of this… I already have a ticket open for issues with the B20x dropping wifi and DHCP without warning
