I have a 40G antenna with 4-LTE connections, but my modem only has 2. what do you recommend for the other 2. should I put a 50Ohm terminator on them or just leave them off?
Buy a BR1 and plug it in the WAN of your current device to give yourself another 4G connection.
Buy a set of adapters and use the 2 spare LTE connections as wifi connections.
Otherwise just coil the cables and tape it. You don’t need to worry about using terminators.
