If there anyone manage to grab information using L2TP environment. Basically a lit confused here. For normal environment is it OK.
For L2tp environment, i got 2 ip segment
local LAN ip address
Mgmt Ip address.
Once the L2TP established, need to use mgmt ip address to manage the devices. Need some advises here.
Do you mean you have L2TP connection to the same subnet of the Peplink/Pepwave unit? So that we want to grab the information from Pep unit over that L2TP tunnel?
Basically, i will hope to able to monitor the cellular or wan connection traffic using PRTG but so far no luck.At pepwave1 create the inbound trafic (port forward) to the server. I use the mgmt ip address inside the (L2tp setup) as my laptop ip address. Is there anything i miss out or else?
Hi Ahmad,
How would the Peplink and Pepwave routers interfaces IP looks like in your environment? As L2TP (I assume L2TPv3) creates a layer 2 connection between both Peplink and Pepwave devices.
At your environment, how the Laptop (PRTG server) access to the central unit of Peplink/Pepwave device, in terms of the routing path?
If the central site Peplink/Pepwave is IP reachable to the PRTG server, and necessary service port(s) open, it shouldn’t be problem to monitor those WAN interface traffic.
-when the l2tp established both peplink will be a L2 unmanaged switch. Need to use the management IP so when to login to pepwave box.
create another L2tp link acts as another remote site and laptop connected to the peplink box(yy.yy.yy.1) and set the management IP address for Laptop.Do the inbound traffic to laptop IP address(yy.yy.yy.2) . Right now only test PRTG with L2TP enviroment, i only manage to monitor LAN that is directly connected. No routing at the moment. Still in the midst of testing. Need your advise on this.
Great news that i able to monitor the WAN,Lan,L2tp using same setup using firmware 6.1.2 beta version. Please help me to verify the availability of 6.1.2 GA version.
