It would be incredibly useful, particularly given the marked Peplink services, to provide 3D CAD models of the various devices. They are generally used in custom installed applications, it would help a lot with integrations.
Hi, I also need CAD’s for the Max BR2 Pro so I can get a case made. Alternatively, does anyone have a case shop that may have done this for them already?
I’m working on a project and I’ve been looking for some time for the STEP files also. It seems they’ve made it difficult to acquire for some reason. I don’t know why as it seems like a potential barrier to possibly using their devices.
about the STEP files. The most straightforward way is to ask to your reseller or VAD from which you purchased the router. If that doesn’t help, you go via Peplink support ticket’ing system where our team will help you.
