Assume a VLAN that consists of two LAN ports and a single SSID. Layer 2 isolation is an attribute of the SSID rather than the VLAN, so if Layer 2 Isolation is enabled:
- Can Ethernet devices plugged into the LAN ports that are part of the VLAN see the wireless devices?
- Can the wireless devices see the Ethernet devices that are part of this VLAN?
- Can the two Ethernet devices see each other?
Thank you.
