Hi all,
After my attempt in having this issue solved through ticket, I turn to you for your expert knowledge.
The setup is two Balance SDX with high availability. Nothing fancy on the LAN side, but customer equipment is going to utilize PepVPN for remote connections.
The HA bit is working just fine, the problem is getting the PepVPN to work.
To emulate the WAN connections at the customer site, I have setup a TST. When I use port forwarding of TCP 32015 and UDP 4500 to the virtual IP, PepVPN is not working. Only when I use the actual interface addresses. As I can’t use port forwarding to two different addresses, this is where my setup fails.
Any idea why port forwarding will not work towards the virtual IP address, and do any of you have an idea for a workaround?
Thanks.
