Hello ,
the traffic not passing when we are connecting the Ubiquity to Trunk port into the balance 210
any solution ?
Not enough info to help.
Share a diagram with IP addressing so we can see if its anything obvious.
If you plug a laptop into the B210 using the same port the ubiquity AP is connected to can you access the internet?
Even if i connect Laptop to the trunk port Iām getting IP
I will share it with once i landed by the plane
