I am seeing a marked wifi performance difference between the balance 20x and a netgear AC1750. Within 20 feet the 20x speed drops by 50% while the netgear has no change. I have tested repeatedly and the same results each time. Is there a know issue with the wifi in the 20x?
Did you ever reach a resolution on your WiFi question? If so, please share.
also wondering if you found an answer https://clickandbuild.com/… the only thing that makes me think… maybe is made to offer top speed only around it? or maybe there’s something in the settings?
Out of curiosity were you running the Balance 20X and Netgear AC1750 simultaneously or did you only have one powered up at a time?
Same time but the radios off on the Peplink.
