I recently had an incident in which my ISP erroneously closed my account. Internet access to my cable modem was cut off, however my Balance 20X did NOT detect the WAN was down thereby causing the device to go offline rather than failover to cellular. At the time, my Health Check Method was set to DNS lookup, so it’s my feeling that the failure occurred because the 20X was able to reach my ISP’s DNS even though internet had been disabled. Interested to hear others’ thoughts on this diagnosis.
I noticed that DNS Lookup is the default and recommended setting, so I’m wondering which other method I should use to prevent such an incident from happening again. I’m using my 20x for live stream production so it’s very important that failures are detected immediately.
Peplink-Balance-20X firmware 8.1.3 build 5060.
