I use a Balance TWO router for my home office. I have used the AP One X to great success over the years but I wanted to upgrade to the AP One Enterprise.
My goal is to use the new enterprise as my main wireless AP and to create a mesh with my AP One X to extend my network throughout the house.
The B2 router shows the enterprise as offline. I put in the static IP address of the enterprise AP and I can log into it just fine. The router and both APs are on the latest available firmware.
I have AP Controller enabled for the management of the APs. It can see my AP One X just fine and it is working well, but cannot see the other one but knows something is connected. I have both hooked up to POE injectors. The enterprise is hooked up to a trendnet one rated for POE++.
When I log into the AP Enterprise, it shows that controller management is enabled so I am at a loss of what is going on.
