Our friends at Frontier BV have put together this fantastic video, showing some of the highlights from our 2018 European Partner Summit. We hope to see everybody again next year!
A great summit! Thanks for putting it on, very informative.
Is there somewhere where I can get a copy of the presentations?
we need it, too.
Best regards,
Gregor
For event participants, you can request a copy of the presentations by writing to [email protected]. Thanks.
Peplink InControl - Slide 6 shows some useful IC2 Numbers for GDPR. Is there a resource setting out a summary like this for the physical devices?
Hi @hcg,
The slide shows how long the data is held by IC2, the devices hold the information until they are rebooted. If you want to clear the data held on the device without manually logging on to reboot, you could set a weekly reboot schedule, from the “Support.cgi” page of the device:-
https://earth.ic.peplink.com/aaaa/bbbb/cccc/dddd/cgi-bin/MANGA/support.cgi (replace Index.cgi for Support.cgi):-
Alternatively, you can schedule a reboot using the InControl tools:-
Group → Settings → Device System Management
I hope this helps,
Steve
