2 x Pepwave flex AP one to make a wireless bridge
#1
Hi, I have two AP flex one 300M.
They are outdor and both have directional antennas.
I mention to use it for a short-range wifi bridge (about 200 feet). On one side might be my Balance 580 and 10-15 clients. On another side of the bridge must be more 3-7 clients.
So I can’t configure it both to work in bridge mode. Could someone explain, how to do that?
#2
Believe you are looking at WDS configuration for the Wireless bridge between the AP one flex 300M. Sample setup can be found as below:
Seem AP One flex 300M only support b/g/n (Single Radio), hence you can only building WDS using 2.4Ghz and 5Ghz is not available.
#3
Thanks!
It has worked.
How may I use channel 14 for wi-fi 2.4 ghz, if it is allowed by law in my location?
#4
May i know which country you are located ? Usually the settings is configuration under country selection. The default channel list will display base on the country selection.
#5
Japan, where channel 14 is may be used.
#6
Channel 14 only for 2.4Ghz wireless b mode in Japan and the performance is limited (11Mbps). Do you still have such old B mode clients devices in the network that require running channel 14 ?
#7
Ok. you are right!
