Hi…
B lancer 305
2 fftn one is static ip with pppoe(WAN1) and other is none static ip with pppoe(WAN2)
None Drop in Mode WAN1 is ok but Wan 2 is kept on Error no cable connected but light looks ok
I would like to set up this WAN PPPoe static ips for LAN is it possible for without Drop in mode.?
Thank you for any advice in advance…
PS. None static ip(WAN2) Dynamic DNS setting how do I get Host name? how should i set up with DNS-O-Matic id and password then what do i have put in Host filed…?
Thank you for your help.
Internet works ok now…
Like you said No Drop in mode just two Wan.
But I have to use DHCP in order to get internet.
It seems like default gateway ip change to Peplink b lancer ip , is it normal?
Or do I set up wrong?
Thank you.
These are all set up… Can you tell me what did I do wrong?
Wan one with 64 Static ips This is main LAN ips.
Wan two is None static ips
Window 2008 64 bit client could be problem? Was working yesterday now does not working but Local connection Looks working but No ping No internet.
Which ip should I assign to Blancer ip? Gateway ip assign by isp is 209.183.14.1 but look like that ip doing nothing so should I assign to 209.183.14.1?
sincer yesterday whenever I change blancer ip I can’t get into web interface… what is wrong?
Also At client side Gate way ip is blancer ip what about DNS ip is blancer ip too?
