2.5 Gig switch ports PVID default selector broken for trunk default pvid selection if used untangling ports. If i try to select default PVID valance 1 default flan the system gets confused and will not give out in addresses on default flan passing through the switch using InControl it shows up default Vlan twice in the list only way I get it to work is litterly setting access default then clicking trunk then custom to add other flans but idk other vlan is default like vlan 100 or so and i switch back to default vlan 1 i will not get connection i need to do access then vlan 1 from there then trunk and add other vlans again its a pain amd you should only see default vlan 1 for the switches not the routers if you are on a switch not router view it applies the router vlan to switches meaning no ip address or internet connection
