Good afternoon. I have a Max BR1 Pro. I’ve set up 3 SSID’s so I can separate 2.4 vs 5ghz and guest frequency connections. All the “broadcast SSID” boxes are checked but only the SSID on the 5ghz frequency is being broadcast. I switched them back and forth from 2.4 to 5 to test visibility. Ive rebooted the BR1 and laptop/phone. Any set up tips will be appreciated!
UPDATE: when I UN-check the 2.4ghz frequency and leave 5ghz checked for just 1 of the SSID’s it stops broadcasting on 2.4 for ALL of the SSID’s according to the Dashboard.
