So i can not get this speedfusion to connect no matter what.
So i have a 1350 behind a firewall it is connected to the internet on wan1. It has a public IP adress x.x.x.x the adress can be pinged from the mobile router. Only ports open to the inside are TCP 32015 and UDP 4500.
Speedfusion menu is setup with remote ID, Local ID and basicly nothing else.
On the MAX HD2 Router
I have 2 simcards for WAN, Internet is working fine.
Speedfusion is configured to match the setup of the 1350.
I dont have any connection between the 2 units it just says starting under the status.
Both units have the newest firmware. Any clues to what im missing?
