Background:
We have a set of on-pole antennas and Peplink equipment (a BR1 and a AP One Mini). They are connected with the in-house network by LMR400 coax antenna cabling and CAT5e Ethernet cabling running in a conduit in a trench to the house, feeding an HD2 (antennas and Ethernet both).
In the same trench there is another, smaller conduit, currently not in use.
Set-up:
We need to run a 110V/20A circuit from the house to the pole. There is a proposal to use the second (empty) conduit for that purpose. The two conduits are close to each other.
Question:
Would the power line be likely to interfere with the existing coax/Ethernet setup? (I am most definitely not an RF person)
Any knowledge or suggestions would be welcome.
Be well,
Z
