Dear Guys,
Could you advise on the best recommended and compatible SFP module both for Balance 2500 and SD switch?
Also let me know if we can order these modules through Peplink?
Dear Guys,
B2500
List of SFP+ Modules Passed the Test with Peplink Balance 2500
http://www.peplink.com/knowledgebase/sfp-module-compatibility-list/
For Peplink Switch, we will update you shortly.
Can we buy these items from Peplink?
Let me check on this and update you.
No plan to include SFP+ modules/Transceivers for the purchase. You need to get it from outside vendor.
I will get back to you on Peplink Switch tested SFP+ module/transceiver later.
@Hootan_Rastkar did you face any issues using or sourcing these SFP+ modules in the field?
Not actually, but I need to make sure about the full compatibility before buying any module to prevent any issue in the future.
I’m using FS.com 10Gb for RCC and B3.
Can you clarify what is this? ![]()
Yes, i use these
3m (9.8ft) 10G SFP+ Passive Direct Attach Copper Twinax Cable 30AWG #30862 $13/ea(1906 pcs in stock)
1m(3.3ft) 10G SFP+ Passive Direct Attach Copper Twinax Cable 30AWG #30849 $11/ea(1058 pcs in stock)
Generic Compatible 10GBASE-SR SFP+ 850nm 300m DOM Transceiver #11552 $16/ea(1552 pcs in stock)
1M LC UPC to LC UPC Duplex 2.0mm PVC(OFNR) 10G OM4 Multimode Fiber Optic Patch Cable #40180 $2.8/ea(463 pcs in stock)
3M LC UPC to LC UPC Duplex 2.0mm PVC(OFNR) 10G OM4 Multimode Fiber Optic Patch Cable #40233 $4/ea(327 pcs in stock)
Hi Team, we would also be very interested in learning what the certified SFP modules are for the switches. This is a very popular question that comes up when discussing the switches. Very exciting!
-Jon Grote
Frontier Computer
According to our Switch SoC provider, it supports the SFP+ transceiver which is compliant with SFF-8431.
We have tested with the followings:
Netgear AXM761
Intel FTLX8571D3BCV-IT
Intel FTLX1471D3BCV-IT
Finisar FTLX8573D3BTL
Finisar FTLX1371D3BCL
We will keep update the list, Thanks
Sorry Keith, RCC and B3 are the customers that we used the cables from fs.com with.
Is there an updated list of known working transceivers specifically single-mode for SFP+? Also, do you know if there are any 1Gbps SFP modules which are compatible with the SD-Switch?
@nikolaus, these are the SFP+ we tested so far.
This is the single-mode SFP+
Can you share the used case of 1Gbps SFP? Fyi, SD-Switch is a gigabit switch. Hence, the fiber uplink ports should support 10Gbps for a common practice.
Thanks for the updated list- I really appreciate it ![]()
As for 1Gbps, my team deploys networks at events and conferences and sometimes link to switches that aren’t ours with SFP transcievers so knowing any that work could be helpful… I understand if that’s not something worth a lot of R&D time and is more of a nice to know question
Guys, I think it’s better for Peplink to sell the certified and compatible SFP module in the online cart as the accessory for SD-Switch and B2500.
Any comment?
Regards/Hootan
Very interesting idea and am curious to see how this pans out :)![]()
Is there any update on tested/supported SFPs on the switch?
