Hello.
When are you planning to incorporate a 10 gigabyte Ethernet port in the Access Points? I have an important business and this feature leaves me out because it is a requirement for educational institutions in Colombia. If I know if it is on Peplink’s development map and what the estimated date is, I could see if I can manage it in some way with the client.
The AP AX does have a multigig 1/2.5Gb port, its not just 1Gb. 10Gb is uncommon on access points, as they dont need that much bandwidth. Only a few multi-radio APs for high density deployments have it.
absolutley correct.
I would bet, with WiFi 7, we will see 10 Gig ports on the APs.
Bryn. Thanks for your comment. I thought the same thing, but Dennis’ comment is true.
On the very high end perhaps. If you look at the wifi7 aps already launched, 2.5Gb & 5Gb ports are common but not much in 10Gb yet.
Bryn, Ok, I think it is rather ambitious for a client to demand a feature that is so rare in the market. It may be that the client made a mistake in his request. Thanks
