I had read older posts that the SOHO supported the use of a USB/ethernet adapter for an extra WAN connection in the original and second versions. I was trying to find the “hidden feature” in the MK3, but could not find it. I may be missing it though. Does anyone know if it is possible to use a USB/ethernet adapter with the MK3?
Hi - welcome to the forum!
Here is the post you’re looking for
That post addresses the original version of the SOHO. Something has changed in the newer MK3. The “hidden feature” to to change it to "USB Ethernet” mode is not available in the MK3, or at least I could not find it. I was hoping someone had figured out how to make it work on the MK3.
