Have a Balance 30.
WAN1 with multiple IP addresses.
Internal server, need access to from outside using one of the additional WAN IP addresses.
Tried using port forwarding to one of the additional WAN IP addresses. This did not work for us.
Tried using NAT mapping to the server from one of the additional WAN IP addresses. This did not work either.
Martin,
Thank you for your response. Port forwarding is how we usually do this, though it’s not working when we point to one of the additional WAN addresses. It will work when we point to the Interface IP but not when we try one of the other IP’s. We are testing with port 22.
When testing against the WAN IP to see if the port is open with shields up or yougetsignal.com port forwarding tester the port shows closed.
Already have Wireshark installed. Downloaded Netcat and tried to extract it and install it and it back with that the file is password protected. So not able to run Netcat.
When testing using the interface IP address for WAN1 everything works fine. When switching the forwarding IP address to one of the additional WAN IP addresses it does not work.
Thank you. Don’t know how I missed that. I was able to get that to work, though the only IP address we can capture on is the WAN interface IP. No option to capture on the additional WAN IP addresses.
Do you mean the capture results doesn’t include the optional WAN IP network packets ? Do you try to access the optional WAN IP from external when you perform packet capture ?
