I’m at an RV resort, and to get access to their Internet, I have to connect via the resort’s captive portal. How do I configure my Surf SOHO Mk3 to connect up going through a captive portal? thanks.
Hi @tcpip95.
@MartinLangmaid has the answer for you here … Use wifi wan with portal captive connection - #2 by dennis.hofheinz :<)
The key is to disable the WAN health check for this endeavor. You may re-enable it thereafter.
Does that work for you?
Rick
LOL Yes, I just figured that out. It worked fine. Thank you!
