Brand new MAX BR1 router, purchased 2 units, first one works fine and the second cannot establish a wifi with any client. Default reset the device, updated the firmware, CPU is always at 100% but any device cannot connect to it. Just says “Incorrect Password” even when there is not password set on the AP SSID. Nothing works. First Pepwave lemon?
We’be purchased 6-10 pepwave devices the past couple of years.
Hi there and thank-you. Yes. I am able to access the LAN interface but Wifi (which is what we need won’t work); Any SSID name, password, no password all give the same message; Incorrect password. Devices sometimes connect for 10 seconds and then disconnect and maybe reconnect automatically again within 5 minutes again.
Will download as you suggested. Disappointed as we have a presentation tomorrow for a large automotive OEM and this was one the core components we sold them. Had one issue with a HD Max4 before where it would power cycle when putting in an ethernet connection but that was quickly fixed with a firmware update. This is not working with either the 8.0.0 or 8.0.1 update. Thanks for the prompt help!
