Hi guys, the Balance 20x has been a lifesaver for me, or more literally, an internet saver, haha!
Here are a few features that IMO would make the Balance 20x or the next updated model even better:
- Wireguard support – WireGuard is faster, simpler, and more secure than OpenVPN). It uses modern cryptography and has a streamlined codebase, resulting in faster connection times and lower latency. WireGuard is also easier to use and has native support on mobile platforms, making it a better choice.
Peplinks says: “We are looking into this and will likely available in v9 firmware.“ - VPN client auto-failover – The Balance 20x VPN client addon is highly reliable because it continuously attempts to re-establish the connection if the VPN provider service drops. However, for users with multiple VPN services from different providers and locations, such as ovpn, NordVPN, and ExpressVPN, adding multiple connection profiles isn’t enough. It would be helpful to set connection priorities so that if the first VPN provider goes offline, the router can connect to the second provider until the first is back online, and so on. Currently, the router only keeps trying to reconnect to the main profile, even if multiple profiles are already added.
- eSim support – eSIMs are fast becoming the future of SIM card technology due to their convenience, ability to support multiple profiles, improved security, and additional functionalities. Currently, to replace the SIM card in the Balance 20x, it is necessary to remove it from the rack to access the bottom compartment where the SIM card is located. eSIMs offer a more convenient, flexible, and secure way to manage connections.
- Rackmount kit– I’m currently using a universal rackmount kit from Ubiquiti.
For your consideration.
Here’s my Balance 20x install into my home lab:
